Results 1 to 5 of 5
    Aug 2015
    Default mercedes ml270 all lost keys - eam 1d69j - help needed please
    Hi all,
    Mercedes ML 270 cdi
    W163
    EAM 1D69J MCU
    All keys lost
    hi can anyone help with making a transponder for a mercedesml270 which i have all keys lost. I have attached the reading from eam 1d69j mcu.
    I tried making key using vvdi2 as its in the list in the immo data section. i tried using unused and used positions, writes successful with super chip.
    but i still get start error on the cluster.
    thanks in advance for any help anyone can give
    Tagne's Avatar
    Aug 2014
    BATA EQUATORIAL GUINEA
    hello mate make keys with original 35
    richard27's Avatar
    Aug 2011
    Today I ran a Mercedes with A160 1D69J mask, but it doesn't have a super chip, it works when I use the original 7935 and Tango.
    VVDI showed all the keys as used, but Tango 1st key was used, 2nd key was empty and OK.
    ​information sharing
    Minsk, Belarus
    Its key #3, write its damp to chip and config its as write in .txt
    Aug 2015
    hi all , as the post says , all keys lost
    i did some checking again and i see that the chip generated is being identified by the das module, it gives me start authorisation in das.
    but no start in ecu, i checked wiring to ecu and all fine.
    there is several fault codes in ecu, i have not attempted to do any coding there so it looks like someone else had a go with it.
    is it possible that the ecu made virgin again , and recoding again.
