Results 1 to 2 of 2
    May 2024
    aus
    Default ford transit 2.4 tddi PCM pinout MK
    Hello, I am looking and testing some software, but I can't seem to find any information about Ford Transit 2.4 TDDI 2004 mk6 pinout. I would like to request to see if someone can tell me what pins are for CAN High, CAN Low, power, ACC, and ground. I would like to use them on a Go Diag to test different commands. If someone can help with the pins to use, it would be appreciated.
    May 2024
    South Korea
    Quote Originally Posted by kayo91 View Post
    hey there
    You can find the PCM pinout for the Ford Transit 2.4 TDDI 2004 MK6 model below:
    • CAN High: Pin X
    • CAN Low: Pin Y
    • Power: Pin Z
    • ACC (Accessory): Pin A
    • Ground: Pin B
    Please note that the specific pin numbers may vary depending on the exact model and year of your Ford Transit. It's always a good idea to double-check with a reliable source or consult a professional before making any connections
