Page 1 of 2 12 LastLast
Results 1 to 15 of 18
    Jul 2016
    Default GOLF MK5 DPF HELP
    Hi freind's, please i need help to remove DPF and EGR from a GOLF V with PPD1.2 simos, i have try many softs but don t work, please can someone help me with a tested solution, i join the dump and hope someone can help; thank's a lot in advance
    Member nuno_205's Avatar
    Apr 2010
    Look this.
  3. The Following User Says Thank You to nuno_205 For This Useful Post:
    Drdiag (24th May, 2024)
    Jul 2016
    Where freind.
    Jul 2016
    thank's freind; is there a tested solution?
  6. #5
    Jul 2016
    Don t work freind. Mil dpf light is on and limp mode after few km. Any tested solution please?
  7. #6
    Dec 2019
    UK
    For PPD1.X it is NOT a switch solution.
    You need to write back the original file and perform DPF value reset.
    Even if DPF is removed you need to do a regenration while driving.
    Soon as DPF light is off stop and write the DPF OFF file and it will be fine.
    After writing disconnect the orange plug FOR DPF
  8. The Following User Says Thank You to peechie For This Useful Post:
  9. #7
    Jul 2016
    I will try and report. Thank s a lot
  10. #8
    Jul 2016
    Hi freind s. Tks peechi. I have try your dump and do all you told me. But after few km the problem is the same. Limp mode and light is on. Any other solution please?
  11. #9
    Dec 2019
    UK
    Did you disconnect the orange plug?
  12. The Following User Says Thank You to peechie For This Useful Post:
    Drdiag (27th May, 2024)
  13. #10
    Jul 2016
    Hi freind. I disconnet the orange plug. And when disconnected check light is also on
  14. #11
    Jul 2016
    Any help please?
  15. #12
    Jul 2016
    Please can someone help ???
  16. #13
    Hazerssmurf's Avatar
    Jan 2023
    Germany
    here pass after thanks+rep
  17. The Following User Says Thank You to Hazerssmurf For This Useful Post:
    Drdiag (28th May, 2024)
  18. #14
    Jul 2016
    Can someone help me please?
  19. #15
    rafal's Avatar
    Jul 2010
    UK - PL
    Quote Originally Posted by Drdiag View Post
    write file from good tuner posted above and don't cry like little boy
    need help
    now my goal is to buy xp-005
    who will help?
  20. The Following User Says Thank You to rafal For This Useful Post:
    Drdiag (29th May, 2024)
