Results 1 to 12 of 12
    Jan 2024
    South Africa (JHB)
    Default 24c eprom dump mileage
    Hey all
    Please could some one assist me with finding the mileage in this dump or what the algorithm is? its from a volvo truck
    Current mileage before it was removed is 565715.4 KM's
    Dr. Zoidberg's Avatar
    Oct 2015
    Talca-Chile.
    mileage in 02d8 - 0317.
  3. The Following User Says Thank You to Dr. Zoidberg For This Useful Post:
    SpikZA (24th May, 2024)
    clusters's Avatar
    Mar 2015
    Canada
    Algorithm is Rolling VDO factor 64
  5. The Following User Says Thank You to clusters For This Useful Post:
    SpikZA (25th May, 2024)
  6. #4
    Jan 2024
    South Africa (JHB)
    thank you but im lost i remember you helped me with that UD quester one with abit more explaining because im retarded.
    heres how you helped me on the last one
    "Mileage repeated 10 times, 052c-055d 5 bytes first four mileage inverted, last byte CS
    Inverted hex to decimal/16 or hex/10 to decimal = KmX10
    CS = Calculator on Byte, mileage bytes added, -1 then Not
    First instance of your file (second instance is 406303.8):
    0520: 00 00 00 00 00 00 00 00 00 00 00 ff 3a dd df 03
    0530: 07
    Hex 03dfdd3a / 10 = 03dfdd3 to decimal = 406267.5
    CS (calculator set to Byte): 3a+dd+df+03 = f9 -1 = f8 Not = 07"
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    friend mileage is from lines 02d8 to 0317 as Dr. Zoidberg says..... and algorithm used is vdo rolling factor 64 as clusters says (565760/64 = 8840 converted to hex = 2288 xor FFFF = DD77 *2 = 1 BAEE, 1 + BAEE = BAEF *2 = 1 75DE, 1 + 75DE = 75DF .......)
    and from line 0318 to 0323 is dec *200 converted to hex
  8. The Following 2 Users Say Thank You to jomberykaso For This Useful Post:
    auto80 (1st June, 2024), SpikZA (26th May, 2024)
  9. #6
    Jan 2024
    South Africa (JHB)
    Thank you so much for everyones time and patience! now let me see if i can wrap my brain around this.
  10. #7
    clusters's Avatar
    Mar 2015
    Canada
    Simplified: calculator on Word, dd77 RoL = baef RoL = 75df, etc.
  11. The Following 2 Users Say Thank You to clusters For This Useful Post:
    auto80 (1st June, 2024), jomberykaso (26th May, 2024)
  12. #8
    Jan 2024
    South Africa (JHB)
    Ok so if i have this correct 02d8 to 0317 is stored from the VDO tachograph if the clusters parameters are set to have a tacho and 0318 to 0323 if it doesnt have an external tachograph.
    0318 to 0323 is the actual mileage which is displayed on this specific cluster and its setup with out a vdo tachograph.
  13. #9
    Oct 2023
    Hello, i have have a read of ecu witch is 24C16, i would like to know the calculation method if it's the same, it' ecu MS 6.3 from Renault truck midlum?
  14. #10
    eliet2000's Avatar
    Sep 2011
    Pixa-Roglet / Valencia / Spain
    Hi, 24c16 = 2kb, your file = 32kb, I have my doubts that this ECU saves the mileage.
    Pepelno Vds Pro
    Mangarrufa Power Solutions
    thank you is free
  15. #11
    Oct 2023
    Quote Originally Posted by eliet2000 View Post
    Hi thanks for your reply, i checked the ODO but can't find, i open ecu and find eeprom 4C16 (similare at 24C16), but i only take file from ktag, any idea or things to do?
  16. #12
    eliet2000's Avatar
    Sep 2011
    Hello, to read the 24C16 eeprom better an external programmer
    Pepelno Vds Pro
    thank you is free
