    Eu
    Default Peugeot 206 PIN from dump and virgin
    I need Pin calculate from dump the next BSI:
    S118085220 C
    BSI E02-00
    9652474780 MG
    I need virgin file too, please.
    Thanks in advance.
    Best Regards!
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    pincode sector in your file is corrupted. (from line 6E to 71)
  3. The Following User Says Thank You to jomberykaso For This Useful Post:
    kusasusa (25th May, 2024)
    Hayssam1's Avatar
    Germany
    Quote Originally Posted by kusasusa View Post
    S118085220 C
    BSI E02-00
    9652474780 MG
    Thanks in advance.
    Best Regards!
    Vin VF32AKFWF44046904
    dump virgin
    Please Press Thanks Button and Reput if i helped !
  5. The Following User Says Thank You to Hayssam1 For This Useful Post:
  6. #4
    Hayssam1's Avatar
    Germany
    unfortunately your file is corrupt no pin code
    I think you can too make immo off
    iaw6lp2.05 immo off or pin code from ecu
  7. The Following User Says Thank You to Hayssam1 For This Useful Post:
  8. #5
    Eu
    I can't get the pin from the ecu either, because I see that the immo is off.
    I entered virgin file in Bsi, but I can't adjust the key and the remote doesn't work either.
    You maybe solution for this case?
  9. #6
    Hayssam1's Avatar
    Germany
    I think so, upload your file and write which ECU is it
  10. The Following User Says Thank You to Hayssam1 For This Useful Post:
    esse (25th May, 2024)
