Results 1 to 8 of 8
    Sep 2010
    Default Ford Kuga DCM3.5 - after OBD flash with Autotuner dead
    please help me. I flashed Ford Kuga 2.0TDCI with ECU DCM3.5 via OBD and everythink looked good - SW said "The ECU has been successfully flashed." but now car doesnīt crunk and ECU is dead without any communication via OBD.
    I have original FGtech and I read the ECU via JTAG but I donīt know what is wrong. For now I have only OBD backup from Autotuner and Jtag backup from FGtech.
    So is there anybody who have Jtag/BDM backup of this ECU or know how to repair this ECU?
    Autotuner support is closed during the weekend.
    Manufacturer: FORD
    Software: AV41-14C204-CM
    Hardware: 0761SA22640933
    Detected ECU: DCM3.5
    ricked's Avatar
    Apr 2016
    Europe
    what are you trying to do? clone, writing tune file??
    Sep 2010
    I made tune file like many times before but now ECU is dead
    ricked's Avatar
    Apr 2016
    Europe
    maybe CS error(i dont have ols btw) some other member can check it for you maybe
    Sep 2010
    I donīt think so, I treid to combine jtah and obd backup and write with jtag with checksum correction but still the same. Fgtech and Autotuner can make checksum - I write this ECU many times via OBD without any problem till now.
    recovery is not possiblem because ECU doesnīt responce via OBD. I tried IDS but still the same, ECU without any communication.
    Sep 2010
    solved by another flash backup, IDS and forscan. now car works again
    carradio2001's Avatar
    Nov 2009
    France
    Quote Originally Posted by vopi View Post
    How reflash with For Scan ?
    Carradio2001.
    ricked's Avatar
    Apr 2016
    Europe
    there are areas in flash files that even winols can not correct the cs so dont say you did not have cs error untill you figure out yourself what the error was, i have been there, all orignal tools here and non of them can do all 100%
