    Apr 2024
    Default cayenne me7.1.1 dtc off
    someone can do dtc delete p0700 U0103 on this one?
    Also ABS has P01314 and P01315 with Gearbox ECU removed, any solution on this one?
    thanks in advance.
    https://www.mediafire.com/file/ktjd4...e+ori+me7/file
    Sep 2022
    Birmingham
    Heres dtcs removed and chks ok
    not the gearbox ecu dtc's
  3. The Following User Says Thank You to brockmoortuning For This Useful Post:
    cayenne521 (25th May, 2024)
    Apr 2024
    Quote Originally Posted by brockmoortuning View Post
    Thanks, with what did you delete the dtc's ?
    I will check it in a bit.
    Gearbox ecu is removed, because there is no need for it, but with it removed ABS has 01314 and 01315 in it and light on, Im still looking for a solution for this one.
    Sep 2022
    Birmingham
    Xdecoder
    Apr 2024
    Xdecoder
    Ah okay, sadly engine light is still on, but no fault in the ecu.
    Apr 2024
    Still looking for an solution, I think cw_can_r is the solution.
    Somebody can skip on in this or has an good mappack for the file?
