Results 1 to 2 of 2
    Aug 2010
    Default R1200C ABS pump no speed on odometer.
    A friend of mine is trying to figure out how to bypass an ABS pump, which in this model (R1200 C 2004) is crap. It was damaged by a high voltage spike. I got it mostly covered except those two marked elements on the picture. My guess is the top one is U5ZA27C and diode below is MURD 30B. However under the U5ZA27C is something withe, like it would be another part. This abs pump is just to not litght an Xmas tree on the dash. Can someone help me and confirm those two elements? Anything else to check?
    Thanks in advance!
    Aug 2010
    No one?
    Can someone at least point me at the documentation for it?
    Or a method to adapt a replacement one to the ECU?
