Results 1 to 9 of 9
    May 2024
    Default need working dump file for Nissan Murano 93c86 chip
    I have made an error and need a working eeprom dump from a Nissan Murano Z51 with 93c86 chip to hopefully recover the cluster ... any help with be greatly appreciated. 🙏
    Sep 2012
    post photos front dash and back pcb-circuit to help with the version file you need and year
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    Quote Originally Posted by kakimoto View Post
    I have made an error and need a working eeprom dump from a Nissan Murano Z51 with 93c86 chip to hopefully recover the cluster ... any help with be greatly appreciated. 
    i saw other post from you with same problem, try one of these file, one of them should work perfectly.
    Sep 2012
    write and test that files of jomberykaso it will work
    May 2024
    I'm having trouble reading the chip .. not sure if it's my chip clip tools or the software I am using.
    I have a GQ-4x4 and an Orange5 .. which software do you suggest to use and what specific chip (manufacturer, etc) as there are so many options for 93c86 like the following for example:
    93c86A (8 bit)
    93c86B (16 bit)
    93c86C (16 bit)
    93c86C (8 bit)
    93c86C*SOIC8
    AT93c86 (8 bit)
    CAT93c86K (8 bit)
    .. and more
    I am reasonably new to this and although I have done quite a few others now, this one is causing some trouble so any help would be amazing
    Jan 2021
    Default Murano
    Hi use orange 5 remove eeprom from board read and write like 93c86 16bit
    Nov 2020
    Dont use chip clip, better to remove eeprom(chip) and read , check whats written on it ie 93c86A, 93C86B ....etc, use ORANGE5 to read the eeprom accordingly
    May 2024
    S93C86
    BDDVA9
    0008
    That's what's on the chip but I ve got no options the same
    Nov 2020
    S93C86
    BDDVA9
    0008
    choose option 93c86 16 bit
