Results 1 to 11 of 11
    rob h's Avatar
    May 2011
    Default Chinese 107 Aygo C1 flipkeys
    Hello guys, i found some flipkeys, that should work on 2005-2013 Aygo, C1 and 107.
    ( Oval badge space, badge not included, will only fit Toyota badge. )
    Sadly, they made these, with 6.85mm baldes, instead off the 7.3mm.
    Seller, wont send me the correct blades, and wont change his product description.
    jingyuqin YanKey Store
    Hopefully, they will fix this, they realy looked good.
    Dec 2010
    Nottingham
    i use keydiy on these for flip key, the 2014 on 2 button toyota look alike flip , work spot on
  3. The Following 2 Users Say Thank You to rapidlocksmiths For This Useful Post:
    rob h (27th May, 2024), wuza (28th May, 2024)
    rob h's Avatar
    May 2011
    The keydiy quality is not good.
    They clearly saved on the production proces. And materials.
    I always used xhorse when possible. Much better casing, and pcb.
    They have a Toyota shaped, 2 button.
    The flipkeys, i found, on ali, looked like oem 108, aygo 2014+. Same blade folding sideways, in the case.
    Sadly, the blades are not the correct with.
    ucokseparoh's Avatar
    Aug 2015
    Indonesia
    Quote Originally Posted by rob h View Post
    I rarely used these universal remotes either from KEYDIY or Xhorse, but a friend of mine sell these a lot. He gives 1 year warranty for KEYDIY's to his customer but he dares not give the same for Xhorse's.
  6. The Following User Says Thank You to ucokseparoh For This Useful Post:
    UK
    Never used anything but KD/XH on these (both old and new shape) & never had an issue or comeback that im aware of.
    As said above the Toyota style one is even an almost perfect lookalike.
  8. The Following User Says Thank You to the_big_d For This Useful Post:
  9. #6
    rob h's Avatar
    May 2011
    Aygo aftermarket.jpgThey look better then keydiy and xhorse,
    Fold like oem, have a transponder pocket, and oval shaped logo fits Toyota logos i have in stock.
    Why did they have to fit a to small blade? It would have been perfect.
    I will not swapp blades, atleast, not planning to.
    They should fix the product, or change the advert.
    Which, they did not do.
  10. #7
    fred77's Avatar
    Jun 2019
    So keys ok but blades fcuk
    u get what u paid cheap like - why post ????
    replace blades tho i guess u post alot so like to chat here your issues love
    Solidarity with Ukraine
  11. The Following User Says Thank You to fred77 For This Useful Post:
    rob h (30th May, 2024)
  12. #8
    Dec 2010
    Nottingham
    i must have done over 50 c1/107 and aygo to 2014 change over using kd using kd b11 and toyota 2 button look alike remote , never had a single one back and all good. ive also done quite a few oem fixed blade on these too, when given the choice between oem fixed blade and a flip the youngsters always go for the flip. but kd has never let me down on these as an aftermarket option nor have i had any comebacks and guarantee them for 12 months confidently .
    if you rate the cases you bought and are happier with these then change the blades , a pain but better than using an alternative your not as happy with .
  13. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
  14. #9
    rob h's Avatar
    May 2011
    Yep, i know, still like thinks to be like they should.
    Just like:
    Renault a4 aes remote keys, nonnflip, to short a blade, so the wont insert fully.
    Opel remotes, with white buttons.
    If halves are screwed down fully,
    And or 2032 battery, instead off 2025 is used.
    Buttons will get stuck.
    ( Logo, 14mm wont fit (13.5mm).
    Every 2008+ vw remote,
    Id48 dangeling or loose inside.
    ( Most seller, send them without the pin inserted, so an easy fix)
    Kidney shaped Hyundai flipkeys.
    The 2 halves, wont stay together, with a single tiny screw.
    ,, nothing we cannot fix. Just not the way it should be,,
  15. #10
    Dec 2010
    Nottingham
    sounds a bit like the price cutting locksmiths , sellers cutting costs and not building or supplying as it should be , just as price cutters dont bother with insurance and want cheapest key.
    when cheap something is always lost as corners get cut , customers want cheap so locksmiths source cheap suppliers then cut corners to be cheap , the world we live in today .
    i spend days every month putting blades on keys and boards into cases , even taught my kids to do this for me .
  16. The Following 2 Users Say Thank You to rapidlocksmiths For This Useful Post:
    rob h (30th May, 2024), wuza (30th May, 2024)
  17. #11
    Jan 2017
    Netherlands
    I agree there is a lot of bad quality out there but KDY 107 in NB11 I agree them to be really good for those cars... The original comes in all the time with worn casings and buttons missing from the board, so far of vast nr of KDY I never got even one back with issues (yes, ok, a drained battery... but even that one never came back again so not the board that was an issue). The VW versions you have to fit a chip yourself so easy to make sure it will be in there correctly, which ever version you choose (UHDS or old style). Those loose chips are mainly an issue with the ones you buy at the price of a beer coin.. you get what you pay for it seems. Easy to fix most of the time but then the saving on price is lost on time spend. Your issue with the 'short blade' is recognisable , the just use the wrong blades in the keys ment for certain cars, but indeed, can be fixed. KDY keys most of the time I prepare some stock so you can make a bunch which is relatively fast work and you can fix the case as it should (sometimes a bit of superglue does the job, like the official Opel and Hyundai/Kia keys are done too).
