Results 1 to 1 of 1
Thread: BMW X1 F48 18d
    Feb 2022
    EU
    Default BMW X1 F48 18d
    Hello friends.
    After getting inside the ECU diesel fuel there are strange things with it. I don't want to bore you because this is long story.
    Everything is checked, including another clonned ECU and I have the same problem. If the motor of the flaps is connected air the flow meter and EGR valve don't work.
    If the flaps motor is disconnected air flow meter and EGR work perfect.
    When I removed the flaps in the software, the air flow meter and EGR don't work, no matter if the flaps motor is connected or disconnected.
    So maybe someone of you have ori soft for this ECU ? This is BMW X1 F48. EDC 17C50 DDE 8 470 176-01 SW 563804.
    I include my ori soft, so you can compare it.
    Thanks in advance.
