Results 1 to 4 of 4
    Sep 2016
    Default PASSAT 2001 ABS CODING
    Hi friends
    how are you
    i have volkswagen passat 2001 with
    motor diesel 4 cylindre ABS 4B0614517G ABS/ESP FRONT 1728 .
    i try to recod it but not succes .
    i try with several access but no way always i found in soft coding 00000 and in shop WSC 00000.
    can some one assist me to resolv this probleme.
    thank you very much
    May 2024
    Transnistria
    Quote Originally Posted by gifret View Post
    Hi friends
    how are you
    thank you very much
    Are there problems with other control units, power steering, steering position sensor, ABS sensors? Dashboard, coding, language, miles and kilometers. I had a problem with the coding of the dashboard, because of it the coding did not work in the ABS unit
    Sep 2016
    hi friend
    thanks for respond
    i just replace dashboard with other the same but i dont know if exist fault before.
    do you think can be something in dashbord.
    May 2024
    Transnistria
    hi friend
    thanks for respond
    This happened to me after changing the language from Czech to English, from Fahrenheit to Celsius, from miles to km, respectively. ABS encoding networks and, accordingly, power steering. Searching through encodings for different countries helped. After the dashboard region matched the native one, everything worked
