    HeXeN's Avatar
    Mar 2015
    Default Mitsubishi Outlander Sport 2018 usa pcf7961
    I have ordered OUCJ166N key from vin numbers, it is 7941 isnide, but car came and has 7961 transponder, anybody sucessfully programmed 7941 in?
    Also will aftermarket 7961 work?
    Outlander sport 2018 usa
    Jul 2019
    Melbourne, Australia
    Quote Originally Posted by HeXeN View Post
    Just looked that part number up, it's bladed. The transponder and remote are programmed separately even though the one chip handles both. It should be fine but I will say I've had trouble with Outlander/Lancer aftermarkets, genuine works forever but aftermarket has issues and needs regular resyncs.
  3. The Following User Says Thank You to Spiritech For This Useful Post:
    wuza (28th May, 2024)
    HeXeN's Avatar
    Mar 2015
    Used Autel and programming: FAILED
    Will try with 7961 aftermarket key when it arrives
    ucokseparoh's Avatar
    Aug 2015
    Indonesia
    can't you generate 7961 out of XT27 then pre-coded it again into ID46 Mitsubishi?
    this has the same system as 2018+ Nissan Livina, I just did one through eeprom few days ago.
    Mar 2012
    If using a non remote key, use 7936 transponder coded to Mitsubishi 46. Works fine. A genuine 7936aa(as) or XT27 coded to Mitsubishi 46 crypto works.
    Jul 2019
    Yes, can snip the inductor off the board, program remote and program separate transponder.
