    May 2024
    Default VW BOSCH MED 9.5.10 IMMO PIN
    Hi!
    Need help with this Ecu. I need the pin for immo to write in vcds and adapt the new ecu to the car.
    Can some hero decode the pin from that file?
    Thanks in advance!
    avital's Avatar
    Yes, it is possible, but you have to activate the glass ball and the grey smoke from the campfire because without the files it requires some additional skills -> in this case wizardry.
    Production and development professional IMMOBILIZER/TCU/ESL/ELV/SRS emulators for all brand cars
    PORSCHE / FERRARI / MASERATI / LAMBORGHINI - immobilizer solutions
  3. The Following 2 Users Say Thank You to avital For This Useful Post:
    fudballer (27th May, 2024), Ogudogu (27th May, 2024)
    May 2024
    Hi avital. I was struggling with attaching files and decided to do it at home after work. Sorry for that! youre absolutely right.
    file should be attached in a zip now. attached the file i got directly from kess
    Ninjor s's Avatar
    Aug 2020
    Bcm2
    Quote Originally Posted by Ogudogu View Post
    ...........eeprom???
    the lesser you use your brain,
    the louder you use your mouth.
    May 2024
    Idk what you mean ninjor. Is it not possible to get the pin with that file in attachment?
    richard27's Avatar
    Aug 2011
    You only added flash, do not read the eprom information and put it here, this will not create a pin.
    ​information sharing
