Hi Guys
I have in a 2021 Toyota corolla hybrid, the fault is hybrid system overheating. There is plenty of coolant in and the 12v coolant pump is new and working as it should. I have the following fault codes.
P0A001c Hybrid/EV electronics coolant temp sensor circuit, supply voltage out of range.
P0AED1C Motor-generator (MG2) inverter temperature sensor - supply voltage out of range.
Has any 1 encountered these faults before, also does any body know where the temperature sensor for the inverter is located. I am starting to think that its part of the inverter/converter unit.
Thanks in advance
