Can anyone help me with what I need to clone this bsi valeo 73006212 soft8.2 which is from a citroen berlingo.
Is a : " micropesseur NEC"
If you no't have tool to read the BSI, do a Immo Off on your ECU and put the new BSI.
Wayne10, thanks for responding.
The processor is Nec as you say in the BSI, but I would like to reset the car's kilometers in the used BSI. This is because it no longer gives information on the dashboard regarding revs, temperature and kilometers.
Can you tell me which programs can read and download?
like wayne did say, make virgin and adapt to car no need to do anything else
all relevant data is in eeprom
UPA-USB with an NEC adapter should do the job.
Thank you Zmann.
Do I have to buy an upa to be able to do it, do I have to remove it or make connections on the board?
I appreciate the help you have given.
With fourteen points of connection done on the board, diagram may be found on the net.
After read you should find it as an attachment, VIN, PIN, mileage (encrypted), etc.
rui (2nd June, 2024)
