Results 1 to 10 of 10
    Oct 2017
    Hungary
    Default Vectra C CIM PIN
    Hello Masters!
    I need a pin code. Vectra C CIM.
    13112786 XU
    68HC908AZ60
    Hayssam1's Avatar
    Nov 2009
    Germany Lebanese
    This file has wrong size Expected file size is 1024 bytes
    that's how it should be your file is very large
    look here for example ===> https://www.digital-kaos.co.uk/forum...=1#post2947226
    Please Press Thanks Button and Reput if i helped !
    Oct 2017
    Hungary
    Quote Originally Posted by Hayssam1 View Post
    I cut it from the big file.
    That's good?
    Hayssam1's Avatar
    Nov 2009
    Germany Lebanese
    Sorry for you that is also wrong maybe you are a different processor
    Oct 2017
    Hungary
    Or maybe so.
    Hayssam1's Avatar
    Nov 2009
    Germany Lebanese
    Quote Originally Posted by sancaman View Post
    Or maybe so.
    unfortunately this file is also large
    look at the picture https://www.digital-kaos.co.uk/forum...=1#post4746166
    Oct 2017
    Hungary
    Top processor. This is the good cut.
    Hayssam1's Avatar
    Nov 2009
    Germany Lebanese
    if you see that I have helped you please press this thanks Button lower my picture left
    Pin
    5596
  9. The Following User Says Thank You to Hayssam1 For This Useful Post:
    sancaman (6th June, 2024)
  10. #9
    Oct 2017
    Hungary
    Thank you for your patience.
  11. #10
    Hayssam1's Avatar
    Nov 2009
    Germany Lebanese
    that's what we are here for you are welcome
    nobody is perfect
