Results 1 to 10 of 10
    Default ALFA ROMEO 156 EDC15C7 IMMO
    Hi.
    Please help me anybody!
    I need delete immo from edc15c7 Alfa Romeo 156 ecus.
    0281 010 335
    I have a full flash dump.
    Thx!
    Jul 2020
    Try this.
    Luk
  3. The Following User Says Thank You to lukkru For This Useful Post:
    Autronico2 (14th June, 2024)
    Quote Originally Posted by lukkru View Post
    Try this.
    Luk
    THX BUT NOT WORKING...
    ALBANIA
    try this .....
  6. The Following User Says Thank You to automobile For This Useful Post:
    Hayssam1's Avatar
    Germany Lebanese
    Quote Originally Posted by cseko View Post
    Hi.
    0281 010 335
    Thx!
    try this file and let me know
    Disconnect immo box or antenna
    Please Press Thanks Button and Reput if i helped !
  8. The Following User Says Thank You to Hayssam1 For This Useful Post:
  9. #6
    dont working...
    Any idea?
    please help me!
    thx
  10. #7
    gwiazdamb's Avatar
    Aug 2022
    PL EU
    dont working...
    Any idea?
    please help me!
    thx
    Immo box must be disconnected or code line
    If it doesn't work, your problem is not the immo
    Look for faults in the cables, fuses, relays, ECU power and ground
    It's best to have the installation diagram handy and ready to go
    PLEASE PRESS THE " THANKS " BUTTON
  11. The Following 2 Users Say Thank You to gwiazdamb For This Useful Post:
    Autronico2 (14th June, 2024), Hayssam1 (14th June, 2024)
  12. #8
    Quote Originally Posted by gwiazdamb View Post
    I disconnected immo box but car dont start. I readed fault with Bosh KTS and the parameters i see: Immo status: Active and Car start enabled: No
    I think the problem are IMMo...
  13. #9
    gwiazdamb's Avatar
    Aug 2022
    PL EU
    What programmer do you use for reading and writing
  14. #10
    Autronico2's Avatar
    Jan 2021
    Italia
    Listen, I immo'd you off as I always do on these cars, I don't know how other users processed the file, but after all these versions that didn't work, I think your problem is somewhere else, check carefully the power supplies and the main relay.
  15. The Following User Says Thank You to Autronico2 For This Useful Post:
