Page 2 of 2 FirstFirst 12
Results 16 to 27 of 27
  1. #16
    z786's Avatar
    10 Steps Ahead of You
    english plz
    "I always tell the truth. Even when I lie"
    "We Taking Over, One City At A Time"
  2. #17
    jackeldestripador's Avatar
    S.A.
    Quote Originally Posted by luisblas View Post
    hola yo tengo un problema parecido, no puedo desinmovilizar un corsa b con ecm 93355059 fdst fq. pudiste dar con la teclas???
    yes it works for that ecu too. Put all FF's inside hc11 remove i*mo and start car
  3. The Following User Says Thank You to jackeldestripador For This Useful Post:
    Jonatanfunes91 (28th July, 2022)
  4. #18
    yes put all FF's iside hc11
  5. The Following User Says Thank You to pastorio For This Useful Post:
  6. #19
    this cdua u posted dont have inmo
  7. #20
    Hi, I have the some problem? Can you remove inmo from ECU corsa?
  8. #21
    DK Veteran MOBILTRONIC's Avatar
    Bosnia & Herzegovina,Cazin
    For reading hc11F1 must changed orig.crystal 16 MHz with 4 MHz and working 100%.ECU must have ext.voltage.
  9. #22
    friend next time not do your life hard:-)
    easy solution and full working,fast too
    http://www.digital-kaos.co.uk/forums...ad-hc11-63266/
    best regards
    scs-mem
  10. #23
    Default Corsa immo off
    Thank you,for your solution but is not a problem to read motorola hc11f1.This is my way.Regard.
  11. #24
    argentina
    wich programer do you use?. Have you the programer scheme?.
  12. #25
    Yes,this pics is for test with UPA 2.3 serial programmer on my desk.Work OK but only changed quartz 16MHz to 4MHz.Regard.
  13. The Following User Says Thank You to MOBILTRONIC For This Useful Post:
  14. #26
    argentina
    thanks for say why to do it.
  15. #27
    Jonatanfunes91's Avatar
    Jun 2020
    Argentina
    Thanks for sharing your experience
    :wink
