this reset is for all iaw 4SF
hello friends this file work for me but let me check the light on. I think it's because that file is for a ecu 4sf.pc and this is a 4sf.ba. you may do a reset file apart from the original file of this ecu? Here is the entire file with 10 blocks. Thanks
I try to change it but when I upload to the ST10 flasher gives me an error (filename not found or invalid file type) I think it is for the chechsum, anyone know how to correct the chk to these files? Thanks
Hola, Becocamba:
?Finalmente, encontraste el IMMO OFF para ST10f280 de Fiat Siena?
Por favor, si tienes data buena para aplicar, post?ala porque tengo un casio de Fiat Siena HLK con IAW4SF (con ST10F280) bloqueado y deseo desbloaquearlo. Tengo las llaves (tipo TP08). Apliqu? la correcci?n de los bancos 1 y 2 de MacGiver, pero igual sigue sin prender y adem?s no puedo agragarle llaves, porque el SBB me dice que no reconoce la ECU.
Gracias.
GJPADRON (R?mulo Lizarraga). Caracas - Venezuela
Hello, Becocamba:
Finally, do you find the IMMO OFF ST10f280 Fiat Siena?
Please, if you have good data to apply, post it because I have a casio with Fiat Siena IAW4SF HLK (with ST10F280) blocked desbloaquearlo desire. I have the keys (type TP08). Correction applied banks 1 and 2 MacGiver, but still remains I can not understand and also appends keys, because the SBB says I do not recognize the ECU.
Thanks.
GJPADRON (Romulo Lizarraga). Caracas -
Maybe this can help you program keys in this type of fiat car.
Chiptronic - Tecnologia Automotiva
for me works like a charm
Please, Dodge Forza with IAW4SGF Immo OFF.
Any Idea?
Thanks.
de hecho si existe immo para esta ecu, pero queda temperatura y velocimetro sin trabajar
https://www.youtube.com/watch?v=X14TWW1nVWg
