Results 1 to 5 of 5
    Oct 2015
    Default 2250 CD TE SB05 Radio blocked and code help
    blaukpunkt
    7 647 300 316
    815BP730081744102
    Albert G's Avatar
    Apr 2016
    Quote Originally Posted by ekoses View Post
    blaukpunkt
    7 647 300 316
    815BP730081744102
    Code is . . 3115
    Don't forget to press the THANKS & REPUTATION button for help in the future.
    If the display continually shows "WAIT" then the unit may be codelocked and will need to be left switched on up for up to two hours to reset before another code entry attempt is possible.
  3. The Following 3 Users Say Thank You to Albert G For This Useful Post:
    asliyucegsm (25th June, 2024), Laurent33 (25th June, 2024), murat332 (25th June, 2024)
    Oct 2015
    radio blocked
    WALES
    radio blocked
    Here you go.... 3115
    wbr
  6. The Following 2 Users Say Thank You to shooting For This Useful Post:
    asliyucegsm (25th June, 2024), murat332 (25th June, 2024)
    murat332's Avatar
    Türkiye
    hi friend test
  8. The Following 5 Users Say Thank You to murat332 For This Useful Post:
    Albert G (25th June, 2024), asliyucegsm (25th June, 2024), ekoses (25th June, 2024), Laurent33 (25th June, 2024), shooting (25th June, 2024)
