Results 1 to 5 of 5
    Default xprog hc05 problem
    Hello ! I have an xprog m (china clone) and i've manage to read a hc05 (0D62J) but i cannot write it. I have soldered the mcu on adapter. Can anyone point me the right direction to write this mcu ? I've tried different osc values but still nothing
    http://j.imagehost.org/view/0962/error
    jackeldestripador's Avatar
    S.A.
    Try this:
    MCU ------- XPROG
    PIN 8 RDI >--B3
    PIN 10 TDO>-B2
    PIN 19 PD4>-B4
    PIN 20 VDD>-VCC
    PIN 21 PD3>-B6
    PIN 30 /RESET>-B5
    PIN 31 /IRQ>-VppR
    PIN 34 TCAP1>-B7
    PIN 58 VSS>-GND
    XTAL on pin 28, 29 (put 4MHZ crystal)
    In Options->Enviroment->Device Check if the oscilator frequency it's the same as you have on circuit
    to jackeldestripador
    Can you confirm that this is working for you ?
    S.A.
    Yes i use it very often. By most of the times i use the adaptor that comes with the programmer
    maybe my programmer is not good because on the adapter i can read the mcu but i cannot write it, if i try to read it on board i get an error : device is silence
