Results 1 to 4 of 4
Hybrid View
    binarycode's Avatar
    Sep 2022
    Default Renault Kangoo 2015 BCM N3 - Flash issue or stuck in bootloader?
    I have a renault kangoo that i wanted to make key to. Without coming to progress of reading flash of BCM via obd they car died.
    BCM N3 284B13124R
    NEC F3376A MCU
    Data is read with VVDI PROG.
    I read both Dflash and Pflash. Tested several machines to get car starting or atleast turning ignition again but its totally dead, all black, no hazard or so on, so i suspect flash is bad?
    Can anyone please check and help me with this?
    Thank you
    Best wishes
    binarycode
    maxonde34's Avatar
    Nov 2023
    Spain
    Which tool did you use to read it by obd?
    binarycode's Avatar
    Sep 2022
    Problem is solved by writing UCH flash + eeprom of working uch > program key > virgin ecu > adapt ecu > car start = make UCH config according to vehicle.
    Data was read with VVDI PROG as written in first post
    Best wishes,
    binarycode
  4. The Following 2 Users Say Thank You to binarycode For This Useful Post:
    Raould (3rd July, 2024), wuza (3rd July, 2024)
    Jul 2016
    Default Renault kangoo bcm n3 dead
    Quote Originally Posted by binarycode View Post
    Best wishes,
    binarycode
    Hi.
    Read your post. Just wondering could i get a bit more info from you. Someone has killed the uch. No ignition or power to the car. I have a donner uch. But can't seem to get it sorted. I have read the old uch dflash and pflash. Just need the steps if you don't mind.
    Regards Craig.
