Results 1 to 10 of 10
    Jun 2013
    Default Iveco edc17c49 speed limit
    Hello
    Looking for help with speed limit in this file. Now propably is 110 km/h need 140 or total off.
    Baddog84's Avatar
    Sep 2012
    Germany
    WinOLS 5, FGtech, Piasini, Powergate M, Byteshooter, OptiCan Dual II, EVC BDM, VCDS, BeeProg+,Ktag, Kess V3, Autotuner, Bflash
    Fileservice
    no thanks no pass
  3. The Following User Says Thank You to Baddog84 For This Useful Post:
    damian475 (3rd July, 2024)
    Jun 2013
    Thank you. Can you share pass plz?
    Aug 2018
    Hello.
    Please turn off the speed limiter.
    EDC17C49
    It is now set to 90Km.
    Thanks in advance
    Best regards
  6. #5
    Johnsy1998's Avatar
    Oct 2019
    United Kingdom
    Quote Originally Posted by dawidhubert View Post
    Hello.
    EDC17C49
    Thanks in advance
    Best regards
    Test this and report back.
    Chiptuning File Service 24/7
    Thanks+Rep If I helped you!
  7. The Following User Says Thank You to Johnsy1998 For This Useful Post:
    dawidhubert (22nd April, 2025)
  8. #6
    Aug 2018
    Quote Originally Posted by Johnsy1998 View Post
    Thank you for the file
    Can I have the password please?
  9. #7
    Aug 2018
    Your solution doesn't work.
  10. #8
    Johnsy1998's Avatar
    Oct 2019
    United Kingdom
    This version should work. Report back.
  11. #9
    Aug 2018
    This solution doesn't work either.
    Problem solved with CK
  12. #10
    May 2025
    Thanks for the decryption key and for sharing.
