tuning map passat 1.9PD 130hk - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
  1. #16
    Top Poster luisfm's Avatar
    Feb 2013
    you mean you can not load a map found on the web to a car?
  2. #17
    Feb 2013
    I thought that while the number of matching ecu and map software can always use.
  3. #18
    Oct 2012
    Quote Originally Posted by luisfm View Post
    every car has his trick...must mod the original file...and can be probblems with immo..you can use only the same style
  4. The Following User Says Thank You to betrescudan For This Useful Post:
    el_futte (22nd August, 2015)
  5. #19
    Feb 2013
    OK. Thank you.
    I'll keep that in mind
  6. #20
    Feb 2010
    Default Is it good for my passat pd 131 2003 as well?
    Quote Originally Posted by obnchip View Post
    here you can try
    Hello,
    Can I use it in my passat pd 131 as well ?
    Thanks a lot !
  7. #21
    Nov 2009
    Poland
    Better will be if you read your dump and do mod
  8. #22
    Sep 2018
    here you can try
    Guys, I can't download this file
    Can you help me?
  9. #23
    Summa's Avatar
    Nov 2018
    Open your own topic or post your file in to the free tuning remap topic.
