No thats not correct...
post your dump and i will clear it for you..
Ok melmar, here is my dump..
According to airbag 6.4 the crash data is stored in the first 2 lines!!!
Thank you for your help.
this is the dump cleared
Your file looks a little wrong at the top...
write this file over the top and you will be sorted...
Thanks to both of you for the replies. There is a big difference between the dumps that each of you have posted. Melmar...you indicate that yours is 100% correct so I think I will use your dump. I will let you know the outcome.
BR
Paul.
Cheers Adam. I'l get the module back and let you know how it goes. Thanks again.
BR
Paul.
Hi.
this is not a correct choice.
airbag reseter 6.4 is a BIGGEST nonsense. You made me laugh.
Other car airbag ecu dump may not be suitable, although it will be thoroughly cleaned.
That's why you need to fix the original crash dump.
One question? What your diagnostic says???
P.S. for analysis original dump.
Best Regards.
This file will be 100% juozas10 is pro on airbag
