Results 1 to 10 of 10
    Oct 2015
    Gabrovo Bulgaria
    Default NISSAN QASHQAI AIRBAG 98820BK50A
    Hello!I have a flooded module 98820BK50A 5F.It cannot be repaired.Can 98820BT50А 5F be installed in its place.When I install it it gives me error B1210.Greetings.
    Jan 2021
    hello colleague, isn't this module from a crashed car?
    Jul 2014
    where it is the eeprom 93c56 file
    Oct 2015
    Gabrovo Bulgaria
    The original dump of the module and after I reset it and installed it in the car is the other dump.
    Jan 2021
    Default nissan
    test this file
    Jul 2014
    your file are byte swapped, if danocar not work, try mine
    Cheers
  7. The Following 2 Users Say Thank You to auto80 For This Useful Post:
    omegata (Today), tato10 (10th July, 2024)
    Oct 2015
    Gabrovo Bulgaria
    I will try on Saturday because the car is not with me at the moment.
    Oct 2015
    Gabrovo Bulgaria
    Hello colleagues! I tried with the dump but it didn't work. The airbag stayed on and now gives me errors B1065 and B1070. Does anyone know how many airbags this module is for. My car has 4 airbags and let's assume two pyro cartridges on the belts.Greetings!
  10. #9
    Jan 2021
    HI there
    This code means the assist air bag module is open. This can be wiring or the air bag itself as well .
    B1065 NISSAN - Assist Air Bag Module Open
  11. The Following User Says Thank You to danocar For This Useful Post:
    omegata (Today)
  12. #10
    Oct 2015
    Gabrovo Bulgaria
    Thanks. Will dig into the installation and pillows colleagues. Regards!
