Results 1 to 5 of 5
    Jun 2022
    Default Nissan micra k12 key programming after bateryy replacement
    Hello
    have old micra k12 2004 customer changed battery code P1611...
    Tried to program keys with autel when going by procedure immo sign gets of on dash but as soon you finish programming and turn ignition n same sign there.
    What other options are to program keys?
    read ecu and bcm and do it manually?
    Thank you
    P&D's Avatar
    Which key PCF7946 or PCF7936 ?
    7946 never lose contact with car
    7936 IGN on/off 6 times - take key out of IGN - hazard lights flash once - Hold the lock button down - and press the unlock 3 times - hazard lights flash twice - key programmed
  3. The Following 2 Users Say Thank You to P&D For This Useful Post:
    fuzz1 (17th July, 2024), wuza (20th July, 2024)
    Dec 2010
    Nottingham
    maybe this old thread will help https://www.digital-kaos.co.uk/forum...cra-2004-P1611 i suspect there will be many more threads on this on the forum , the search function will find and list them so you can view how other members have solved this issue.
    this fault is common after low voltage cranking or changing of parts , check fuses and relays , try battery reset , delete fault codes in ecm and all modules . reinitialise ecm and nats.
    of course you dont know if the customer has caused other issues when changing battery , cross polarity , changing battery with ignition switched on etc , may have corrupted something or blown some fuses.
    Have you fixed this yet
    super jumbe's Avatar
    Livingstone
    Try this always works for me, switch ignition on remove either battery terminal and live ignition on for 2min while battery off, replace battery terminal start vehicle from where you left ignition on tell us the good news.
