Results 1 to 5 of 5
Hybrid View
    Dec 2010
    Nottingham
    maybe this old thread will help https://www.digital-kaos.co.uk/forum...cra-2004-P1611 i suspect there will be many more threads on this on the forum , the search function will find and list them so you can view how other members have solved this issue.
    this fault is common after low voltage cranking or changing of parts , check fuses and relays , try battery reset , delete fault codes in ecm and all modules . reinitialise ecm and nats.
    of course you dont know if the customer has caused other issues when changing battery , cross polarity , changing battery with ignition switched on etc , may have corrupted something or blown some fuses.
    Mar 2010
    Have you fixed this yet
