    Dec 2010
    EU
    Default Ford ARC code help
    Please help with the code for this old Ford ARC?
    Thanks in advance@all.
    Albert G's Avatar
    Apr 2016
    Quote Originally Posted by simche View Post
    The code is the . : . 6992
    Don't forget to press the THANKS & REPUTATION button for help in the future.
  3. The Following 3 Users Say Thank You to Albert G For This Useful Post:
    Laurent33 (21st July, 2024), lucic66 (21st July, 2024), simche (21st July, 2024)
    Dec 2010
    EU
    Unfortunately, something is wrong with the code.
    I entered it three times and confirmed it on the select button, and after the third entry it told me to wait 30 minutes...
    What's the problem? I connected everything correctly.
    Thanks in advance.
  5. The Following User Says Thank You to simche For This Useful Post:
    Albert G (21st July, 2024)
  6. #4
    In some posts confirmed that it can be calculated as M series. Try 9104
  7. The Following 3 Users Say Thank You to neeewww For This Useful Post:
    Albert G (21st July, 2024), shooting (21st July, 2024), simche (21st July, 2024)
  8. #5
    Albert G's Avatar
    Apr 2016
    Quote Originally Posted by Albert G View Post
    Thanks in advance.
    Hello my friend,
    The real code is indeed . . 6992
    But try the serial code ( M ) . . 9104
    Code Entry as Follows:
    Switch Radio On - Display Shows
    CODE with " - - - - " flashing
    Press preset " 1 " repeatedly for 1st Digit
    Press preset " 2 " repeatedly for 2nd Digit
    Press preset " 3 " repeatedly for 3rd Digit
    Press preset " 4 " repeatedly for 4th Digit
    If the correct code number is now shown
    Press " SELECT " to Enter
  9. The Following 2 Users Say Thank You to Albert G For This Useful Post:
    Laurent33 (21st July, 2024), simche (21st July, 2024)
  10. #6
    Dec 2010
    EU
    It seems to count as an M series. I wasn't sure so i asked. Anyway thank you both.
    9104 is the correct code.
    Best regards!
  11. The Following 2 Users Say Thank You to simche For This Useful Post:
    Albert G (21st July, 2024), neeewww (21st July, 2024)
