Results 1 to 15 of 19
    Birmingham
    Default diga consult compatible interfaces with universal tacho
    hello need advice I can buy an oldish diga consult off a mate for ?300 its got all the leads etc that came with it but its not been updated for atleast 8-10 years so how much would an update cost and will the adapters/interfaces from a tacho universal work on the diga eg bmw key reader, etc etc etc would I need a can adapter being as the kit is so old? i dont know what to do the tacho universal with all adapters is only cheap and looks more tempting. is the diga a better unit or is the clone just as good
    drpeter's Avatar
    The Netherlands
    Quote Originally Posted by neil12345 View Post
    The new clone handheld is perfect, some cables and dongles of the clone are not working, the 9s12 dongle is often faulty, the 95XXX board and the 206/Megane cable. Some people also had problems with the NEC dongle. But I have a solutions for all problems, even for the old sync problem.
    Buy a new clone with all new cables, my advise. You can buy dongles and cables seperate very cheap.
    www.ecutool.com
    Germany
    Hİ BMW KEY KM CHANGE PROBLEM TACHO V2008
    (*) ISN'T READING
    PLEASE ,DO YOU HELP
    WHAT MUST I DO
    omglol's Avatar
    Jan 2009
    Europe
    Quote Originally Posted by drpeter View Post
    www.ecutool.com
    Peter, do you also have solution when machine does not want to read EEPROM? I have changed the 74HC541 (I put this one: http://dl.dropbox.com/u/2523271/diga/06062010300.jpg), but machine does not want to read anything ... What else could be wrong? Thanks!
    there are 3 vers of tacho pro or universal as its called 2008.01 2008.03 the latest ver is 2008.07 thats the one ya want but they mostly sell old stuff 2008.01 old and the screen colour change from green ta blue i think if i am correct
    so dont get stung with an old ver m8 the 2008.07 is the latest ver so far cause thats what iam on the hunt for now
    z786's Avatar
    10 Steps Ahead of You
    first of all mate, if you check the date of this thread, its very old
    second of all wateva u jus sed doesnt make any sense so pl dont giv advice dat even ur not sure about
    thers no such versions as the ones you'v stated, they only show u dat 2 make u think your buyin a new machine
    "I always tell the truth. Even when I lie"
    "We Taking Over, One City At A Time"
    Z786 thanks m8 so there is only one model out there ver 2008.01 and thats it...... the crafty sly sods man what a minefield this is bummer.......
    z786's Avatar
    thats nothin yet mate
    have a read thru this
    http://www.digital-kaos.co.uk/forums...e-china-51972/
    Can give you 1 advise for buying a clone diga consult, tacho pro or universall.......
    Buy the unlocked version 01/08.
    I sell more than 50 pc, never had problems with 01/08, by version 07/08 with red mainboard inside always problems.
    These are really bad......
    The good one`s are these with green mainboard and cpu board....
    Quote Originally Posted by gijsvm View Post
    Hi Friend, i have just buyed a 2008/01 version with green screen.I had a 2008/07 version that switched off and doesnt start anymore.It has the red mainboard as you say.Do you know if it is possible to get a solution for this problem with 2008/07 version? Thanks
    DK Veteran BeianM's Avatar
    Dorset UK
    Quote Originally Posted by marincovich View Post
    You need to do the repair, did you not get the parts with it?
    It doesnt come with the repair kit.
    My problem is that when i was making a chrysler cluster, suddendly switch off the hand held, and since then it never switch on again.I tryed to connect power supply bye obd interface and by power supply direct from the battery but it doesnt work.I dont hear the relay working.When it switch off i was taking power supply by the 12 volt port from the lighter cigarette car.I need some help if you could.Thanks.
  13. #13
    Default Where to buy working clone diga consult
    Can you assist with a couple of places where I can buy this working version? (urls)
    Is this unit working well with european cars, like Volvo, newer years? (I need V70 2001-)
    Thanks!
  14. #14
    Would this tool work on newer Volvo (V70 2001-, V50..) ?
    If not, any other working tool for these cars?
  15. #15
    martij976's Avatar
    Hi marincovich!
    Have You solve Your problem with Tacho?? Cause I have the same symptoms as You described... Working on Dodge Neon 2001 (Chrysler) and hand held stop working.... U have any idea??
