Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: cas3 programer
    Feb 2010
    Default cas3 programer
    i have got a cas3 programmer cas/9s12x bdm with rosfar software(chineese clone)
    i asked for a red one and got a blue one .
    i can read ezs for mercedes 209 and 211 and cas 1,2 providing it has MC9S12
    if i try to read hc12 it wont connect to board just trie linking 6 times and out.
    i need to read a dash for a 2003 mini and i cannot.
    is there any one out there that can help out in fixing the cas programmer or do i have to buya new one. cant send this one back as i have had it for a while using it for cas only.
    or is there away to power up the board so that i can read it
    regards
    hcip's Avatar
    Dec 2009
    From the heaven of paradise in the middle of happiness|hobby:__Bedtime| Sex:Female|Status:Not_Virgin
    update the FDTI driver for the newest one
    Stupidity is not a disease, because there are no existing hospitals for Idiots!
    Feb 2010
    Quote Originally Posted by simon77 View Post
    regards
    i have this cas3 programmer and i wanna make cas3 but when time reading program say decoding and my pc frozen.. and know this problem ?
    DK Veteran deffc0n's Avatar
    Aug 2009
    UK/POLAND
    Check diffrent PC
    Member leon.79's Avatar
    Jan 2010
    i have the same problem but i have a red chinese clone
    cant read normal cas 2 and 3 only cas3 x .
    where can i find the newdriver?
    Aug 2009
    Quote Originally Posted by leon.79 View Post
    hi have red case where have you buy your i have same probleme i have make great cas3XDP512 but cas3 9S12DG256 sofware go at licking 1 2 3..6 and say me securised and dont read !!!!
    Feb 2010
    powered up clocks with external power done the job
    thanks all for your help
    regards
    Jan 2010
    thanks but can you explain a little more
    what is power up clocks with external power.
    Apr 2010
    I would like to know too
    Thanks mate
    Jan 2010
    found out about the external power but still no linking
    anyone got more ideas?
  11. #11
    Jan 2010
    found the problem
    for cas2 reading
    swith the black and whit cable of the coax on the crystal
    reads and write without a problem
    hopes works also for you let me know
  12. #12
    MACEDONIA
    Maybe someone have dump from atmega for cas3 programmer?
  13. #13
    Aug 2009
    found the problem
    for cas2 reading
    hi my friend can you give me more detail i dont understand swit black whith coax cable if you can post picture your modification thanks so mutch
  14. #14
    Jan 2010
    there are 2 wires on your cable
    1 is with 5 colors
    2 is with one black and one white(coax cable)
    inthe manual it says where to solder the cables
    now solder the 5 colors on the places as in the manual
    then you have 2 wires left , one black , one white (coax)
    solder the white cable on the place of the black and the black on the place of the white.
    Let me know or it also works for you
  15. #15
    Aug 2009
    1 is with 5 colors
    strangely it need reverse black and white coax wire right?
    because on the cas3XDP512 i have make correctly coax cable same in picture manual and work fine software go on decoding but cas3 BLACK 9S12DS256 with same picture manuel go on likcking
