Which example file did you use?
I too have this problem, as I installed it on my DM800 HD and no matter how many times I installed or uninstalled, and used 3 different versions of Cccam, blue button, and even manual install I couldn't get a CFG file to appear. Maybe you might be able to tell me which example file you used, as I'm unsure on where to find a good one.
You can drag an drop your own in etc if you have one on PC. Or look for cfg/ config from your download panel on Dm
Tspanel has it in
Thanks. I think TS Panel is an optional addon, as I couldn't find it anywhere.
I have a CFG file from 2.1.4 so I will DCC that over. Cheers!
CCCam is definitely working, as I just disabled it in the CAM manager, and lost all the SKY channels I had working (just need the boxkey and cfg for the movies and sports). Thanks for your guide on that part, I will take a look when I have copied the CFG.
Cheers
sorry to jump in on conservation //the 2.1.4.ccam when downloaded through addons does that go into etc file once downloaded ////how do you open the file //for clines //etc all help appreciated thanks
var // etc // right click config file and the click edit. delete whats in there then put cline in click save and your done
hi mates!!!
i have dreambox dm 500, i setup flash image gemini 4.70 and the problem is that when i start the box it shows only the gemini image for a few seconds and i lose the picture...
any help please
I have been flashing my dm800hd but I cant seem to find a compatible image I got an oozon image with no cccam cfg i tried to install manually but no luck.
any advice please///
Put Dreamelite Phoenix Edition on it or add Ts panel you will get what you need off there.
http://www.digital-kaos.co.uk/forums...11-phoen-2411/
http://www.digital-kaos.co.uk/forums...nel-v6-8-2460/
Andy.
I have a DM800HDPVR clone with a Nemesis 2.3 img. Would like to install CCam. I have done that numerous times in the past using my old DM-7000S, but can't do it with the latest STP. I found this thread, but do not have privileges to download TSPanel.
How does one achieve such privileges, I wonder?
Edit: by posting, I guess, since I was able to download it. However, the file from /tmp doesn't seem to work.
Back to the drawing table...
This is my first posting here, so please be patient with an old fool asking self-evident questions ;-)
BR,
JerryCot
Scandinavia
Hi All, I have a similar problem. Just reflashed my DM500S with Nabilost using Dreamup. Run through the set up procedure when connected to my TV, checked my IP address in 'Expert Setup' and then used DCC to conect to the Dreambox, so far so good. Tried to find the Ccam.cfg file under var, but nothing there?? Back to the Dreambox, press the yellow button twice to initiate the 'Addons download manager' select 'Nabilo Image Cams' and the screen displays.... 'Sorry, connection to server refused'??? i'm lost. I have carried out this procedure before with the results I expect, Any help would be greatly appreciated.
Anyone having problems connecting to their box getting a "10057" error on a clone box belonging to a mate. Used both crossover cable and modem.
Is it possible the seller has changed the password?? Tnx
