Results 1 to 8 of 8
    Jul 2023
    Default Vito edc17cp10 dont start after write dpf and egr off
    Hello,
    Have problem and need please solution
    payment no problem
    also mercedes vito edc17cp10 2013 3.0 diesel
    i have read with autotuner bench and make dpf egr off
    and now car dont start dont crankle nothing
    i have access to ecu and can read dtc there is nothing
    but i have other dtc in other modules
    i have try to write back ori file but not succesfull
    C100
    D10B
    4804
    4759
    FapDpfservice's Avatar
    Sep 2021
    Hello load here dumps to look what happen.
    <a href="https://www.evc.de/en/check_evc_license.asp?k=JETn6EjRQpeE9y4%2fKKRgkQ%3 d%3d" target="_blank"><img src="https://www.evc.de/common/check_evc_license_image.asp?k=JETn6EjRQpeE9y4%2fKK RgkQ%3d%3d"></a>
    Jul 2023
    ok i will now upload all ....
    Jul 2023
    on 26.07 this was first read you can see back-up from AT
    then i have write the dpf and egr off file car dont start nothing no crankle
    then i have write back the ori file but not the back up file only normal file no changes
    also then i have write the full back up what i have read first time and the same nothing changes
    Jun 2020
    ecu dead
    Jul 2023
    i dont think so, with diag have communication and read write all fine
    Dec 2022
    don't trust cracked soft for dpf egr...
    vito no crank corrupt immo data
    vito crank no start bad flash file
    Jul 2023
    Quote Originally Posted by antonis132 View Post
    ok i understand can you help me?
