Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
  1. #16
    Meat-Head's Avatar
    Quote Originally Posted by PierreTheron View Post
    Hi got this Rover sorted in other thread.
    Meathead, do you still want to know where the barcodes are stored in 93lc 66 dump of the scu.
    Regards
    Pierre
    YES PLEASE, very sorry for late reply, only just see your post?
    What other thread is that?
    Thansk
  2. #17
    PierreTheron's Avatar
    Aug 2009
    Centurion,South Africa
    Default Rover Scu
    Meathead
    First check other thread .
    http://www.digital-kaos.co.uk/forums...rtible-121135/
    I will discuss there.
    Need to pull bin from there to show you where they are.
    Regards
  3. #18
    Jul 2010
    west mids, uk
    yes please, but am i right in thinking that if i load virgin file to eeprom, all i have to do is program remotes in with mvp etc and it will work??
  4. #19
    Aug 2009
    Quote Originally Posted by ninja123 View Post
    You can get the barcodes for the locked scu out of the dump ,so that you can reuse the old remotes if they are still working correctly.Just you will not know which barcode goes with which remote for the locked SCU.
    You have to add a new remote to the dump with special software to unlock the SCU, then you can use t300 to put back the old remotes to work with that SCU.
    You can also write these barcodes into another SCU with the software and unlock that one.
    Another way that i done is to input the eka code( that i got from dump in SCU) with the key on the doorlock.
    When the SCU is locked you must follow the correct procedure for this manual key input.( i had to replace the lock before i finally got it right, it was worn out)
    I explained this in above link from previous post.
    Once you have got the Car to start you can use T300.MVP to write in a new remote or reactivate the existing remotes if they are in working order.
    Regards
    Pierre
  5. The Following User Says Thank You to PierreTheron For This Useful Post:
    HeXeN (15th November, 2015)
  6. #20
    Sep 2016
    Belgium
    Hello , iam new here and i would like virgin copy of this pektron scu file if you can send me one ,my i have reader for my chip and i got the code but i do not know how to virginize it and i stuk in the way , wish u can help me
  7. #21
    Aug 2009
    Hi m8
    From where you got reader to see the barcode from the remote????
  8. #22
    Sep 2016
    Belgium
    I have serial pic programer and get the chip out with work station out of the SCU and just read it 8 bits then used software to get my code from it Immo code calculation method M8 but iam stuck in strange thing i never see in this car becuase alarm sound like pip in every secand without stop when i set back SCU and ECU (both in original software) just replaced the Relay of the SCU (pektron with 93lc66a
  9. #23
    Meat-Head's Avatar
    Huh, try disconnect battery, get a diaper pin or simular, piece of wire down to ground, hold on pin 1 off eeprom, bartery on, ignition on, release wire, ignore siren, see if that helps.
    rumor stares yiu MUST MUST MUST get 1 key at leadt working.
    had couple of years ago guy briught new SCU ?55435565666 took it ONLY
    dealer this side of haidraibs wall, who deemed it locked up & scrap.
    rumor stares you get 15 trues to code key then turns into a pumpkin
  10. #24
    Aug 2009
    Rumor states that you will need to upload your 93lc66 file here so we can take a look at it ..
    I think you will be needing a new remote..
  11. #25
    Jul 2016
    Good Day
    My name is Nicky from Durban SA.
    Could you please assist me with some info on how to programe a new oval fob on an mg tf?
    The owner lost his keys and i have a new fob *OC8F0ED66040804329582E* I have attached the dump below
    and would appreciate if you could guide me on how to enter that code into the dump. I have a programmer to write to
    the 93c66 chip.
    Many Thanks
    Nicky
  12. #26
    Aug 2009
    Here added..
  13. The Following User Says Thank You to PierreTheron For This Useful Post:
    rovertechwm (9th July, 2019)
  14. #27
    Jul 2016
    Thanks very much.
  15. #28
    Aug 2009
    Just a tip
    Xhorse remotes on these are very cheap to generate . Trick is to add it to the SCU ....
