Results 1 to 15 of 28
    Staffs UK
    Default MG/Rover Pektron Virgin dump?
    Does anyone have a virgin dump from a Pektron immo (not 5AS) for an MG ZR 2004?
    256 byte 93lc66a
    VIN @ 017F-018F
    Apparently you cannot fit a previously used one to replace a faulty unit.
    Meat-Head's Avatar
    *CONFUSED*
    iF YOU HAVE a keyboard that plays up chuck it.
    take it you mean "SCU" if you swap that 93c66 eeprom from dead unit to new unit/second hand, the customer is none the wiser. Engine starts remotes work, but 99% sure/THINK you need Testbook to 'activate front frog lights and bi-day' (rear wash wipe)
    you 'cant' use secondhand remotes unless your programmer can suck out the codes, 14 didgit (ish) for you to re-use,
    If you have had 15 goes key programming and locked up the unit, battery off vechile, short pin 1 of said eeprom to battery and power up.
    NB you will need ear defenders as the alarm siren will kick in untill it gets bored, tough shit, stuff with rags
    I bust my programmer a few months ago, but if you want can stick a USED 93c66 eeprom in the post (2nd class) if you PM postal address.
    Wirral
    whats the problem? is the unit faulty or lost remote? you can write a new remote into dump if its lost keys. Dealers would just replace it.
    J
    Essex
    tradeonly
    this is a good freind of mine developping his own software tools for the job.
    Staffs UK
    thanks for the replys,
    I had a faulty SCU with no working remotes (also no comms with T4) and I wanted to fit a used virginised one with T4.
    As it is I dumped the 93lc66 and added two new remotes then refitted it.
    It appears OK now.
    I would still like a virgin dump so I can have one ready on the shelf for next time though.
    I just dont fancy buying one from rover to dump it.
    I thought if you just swapped the eeproms you would still have to match the "new" one to the ECU?
    Default Rover SCU Virgin File
    here you go Virgin SCU File
    HTH
    Teckie2
  7. The Following User Says Thank You to teckie2 For This Useful Post:
    StevenJD (24th November, 2016)
    Meat-Head's Avatar
    Quote Originally Posted by nutloose View Post
    Don't ask questions, but it is possable to get a secondhand unit with pre-programmed keys, fit it and match up to the orignal engine ecu.
    Teckie 2
    Where are the keys stored in here?
    PierreTheron's Avatar
    Centurion,South Africa
    Hi thanks for this help full info.
    Have got rover mg TF with no key fob .
    Have got rover Mg ZF with faulty SCU With programmed keyfob .
    Will swop ee prom and see what happens.
    How do you programm remotes into scu eeprom.
    Can t300 pull eka code?
    Answered my own ? T300 can pull the code and kill it as well,Pulled code and then got in wrong menu- code remotes , could not get out , unplugged, Car not to start after that.
    Can find remotes local at 280 euro a piece.
    Where can i Buy these oval pectron remotes ?
    Pierre
  10. #9
    ineed dump for sonata 2005 93s56
  11. #10
    kugglefischer's Avatar
    In an Ecu
    Angry
    Quote Originally Posted by khalidassrory View Post
    HEY!
    DONT BUMP IN A THREAD THAT HAS NOTHING TO DO WITH HYNDAI SONATA'S!
    START YOUR OWN M8!
  12. #11
    Meat-Head's Avatar
    Quote Originally Posted by kugglefischer View Post
    HEY!
    START YOUR OWN M8!
    WHAT ABOUT BUMPING A THREAD WITH A SPAM POST NOBODY ANSERED A MONTH AGO? - SORRY CAPS LOCK
  13. #12
    Default Rover with Scu
    Hi got this Rover sorted in other thread.
    Meathead, do you still want to know where the barcodes are stored in 93lc 66 dump of the scu.
    Pierre
  14. #13
    west mids, uk
    Wink
    i would like to know where the barcodes are stored mate
  15. #14
    west mids, uk
    also, if i use the virgin dump, can i just program new fobs with testbook, t300, mvp etc??
  16. #15
    Sep 2010
    Default virgin dump for pektron ccu
    hi i have this file if you require it but will need coding with t4 and one new plip
