Results 1 to 7 of 7
    Italy
    Default Toyota Yaris ecu Bosch im*o off
    I have a car with a unique key broken. I would like to remove im*o the ecu bosch number is: 0281011649. Can you help me?
    Thanks a lot
    Andrea
    rabie_m's Avatar
    Jun 2009
    morocco/sale
    post your eprm dump
    Italy
    the 29f400? or 95080?
    Impossible to remove the immo from the ECU.My suggestion is that If it is only the key that is broken and the plastic head is still available, (because is the one holusing) the transponder you can then make another 2 or 3 copies of your key from your local locksmith before the worst situation of all key lost happens.
    Best regards
    Top Poster + jimthejock's Avatar
    Scotland
    Default yaris
    what year is the car some basic information apart from the ecu number would really help you find a solution easier it is very difficult to work with nothing
    here is some basic info for you if it only has an integrated ecu then write a new key into the ecu if you can read the eeprom in it or if it has an external immo box write the key into that but not knowing what year the car is i dont know what one you have which brings us back
    to post the information if you need the help
    Jimmy
    hi
    send dump from seperate immobox eeprom 93c66 or similar
    and i will make autolearn dump for you
    Italy
    Thanks a lot at all, but the car has been demolished.
