Results 1 to 7 of 7
    Jul 2008
    Default 600c pvr problem
    Guy's I've been trying for 2 day's to put a image on a new 600c pvr, I've tried every way suggested on this box, dream up, telnet,flash pro wizard, its like theres something missing in order for it to connect using null modem cable, even tried that on every comm port, I know thats working because I've flashed plenty dboxes with it, any ideas?
    cheers
    caveman_nige's Avatar
    Feb 2008
    In my Cave
    Maybe the Dm600 is DOA, have you got another box you can connect to to verify your kit is working as you say though, just in case something has changed its config etc Com port baud rate etc)...
    Btw is it a genuine box or a clone...?
    Jul 2008
    It's a clone m8, I can access the box and change network and scan for channels etc, just cant seem to get a new image on it,tried the telnet and even flash pro wizard cant connect with it, although dcc does, weird one .
    cheers
    Feb 2008
    In my Cave
    I have always had to flash my 600 the hard way...Using Dreamup and a Null modem cable. When i restart my box with the nmc linking the box to my laptop, dreamup says its connected to the box etc, does your even get this far or does it just continue to boot etc?
    Jun 2008
    i use the dreamup method aswell,i dont think you can use flash wizard pro with dm600
    Jul 2008
    Yes when I connect via nmc I see what the manual say's I should but then just hangs there and does nothing..even left it for half hour still nothing, it has a enigma sign on screen and I can scan after I put the cable xml in but looks like Im missing a bootloader or something?
    cheers
    Jul 2008
    Panic over guy's managed to do it through telnet, all sorted now, thanks for all your help.
    cheers
