Send the part number of the engine ECU
Serge
Got a 1998 Landcruiser petrol 4.7 litre come in as a lost key from a car dealer, someone else has already had a go at removing the 93c56 chip maked IC900 on the ecu, I believe trying to remove the immo.
Now I have not done one of these before but believe that this is the right chip, but it is now blank, can anyone confirm that this is the right chip for immo removal on this vehicle?
Also does anyone have a dump for this so I can get this car sorted, either a dump from a working chip and I can program a transponder to match it (using TMPro) or an immo-off dump?
Any other helpful advise most welcome
Eric
Serge
Hi guy try this
hola amigos tengo un toyota prado lan cruiser... quemo la ecu... al rempazar por otra ecu... esta biene con immo y la quemada no... hay alguna forma de eliminar el immo de la nueva... saludos..
5VZ
8966-60100
275000-0086 M/T
hi you prado has an immo boxkey is coded to this
if its is a 100 series box behind the radio
if 120 series then above leftcubby
hello friends I have a toyota lan cruiser prado ... burn the ecu ... the other ecu rempazar ... is fine with immo and not burned ... is there any way to remove the immo of the new ... Greetings ..
good afternoon ... the immo ecu to buy it .... toyota ecu but not burned ecu .... let me know if you can install this by removing the immo ecu .... Greetings
hi guys
i have the same problem with my ecu.
it doesnt have the ic900
does the master key file do the job?
what is this file?
its not even a hex!
how can i use it?
