Results 1 to 8 of 8
    Aug 2024
    Default siemens VDO CDR 2005 code
    Hi there, I'm looking for the radio code reset for siemens VDO CDR 2005 for a 2003 vauxhall corsa c.
    Serial number GM020543467407
    If someone could point me in the right direction that would be great, thanks.
    Jamie
    dvb_gsm's Avatar
    El Jem/Tunisia
    Hi..
    send a clear image of the label
    Dec 2010
    EU
    If you only need to reset the code entry, leave the car in the ignition or if both voltages are connected in the workshop, it will reset itself in an hour...
    WALES
    Quote Originally Posted by simche View Post
    This model needs "AS" to be held when powering on for code entry.
    wbr
  5. The Following User Says Thank You to shooting For This Useful Post:
    simche (24th August, 2024)
    WALES
    Quote Originally Posted by Jamie183 View Post
    Jamie
    Post dump from 24C16 smd eeprom for code
    wbr
  7. The Following User Says Thank You to shooting For This Useful Post:
  8. #6
    Aug 2024
    I need the 4 digit code to get it out of safe mode, and it's not in the docs or manual, thanks!
  9. #7
    lucic66's Avatar
    Aug 2015
    Must read 24c16......
  10. #8
    Aug 2024
    How do I go about this with absolutely no background or equipment? Sorry I am very new to this
