Results 1 to 4 of 4
    Nov 2017
    iasi
    Default Citroen C5 x7 136 HP automatic DPF. EGR off - proper solution?
    Can someone help me with a DPF/FAP removal for a Citroen C5 2.0 Automatic?
    The details are as follows:
    Model: Citroen C5 2008 (X7)
    Engine: 2.0 HDi
    Gearbox: Automatic aisin am6
    ECU: PSA Delphi DCM 3.4
    HW: 9663548180
    SW: 9667098880
    Thank you!
    - the car consume less fuel with original software (compared with some bad off solution.)
    - the particulate filter temperature report 700 degree from first start.
    - car report higher air value measured vs required
    Styber's Avatar
    May 2020
    D8CA4 - set to 0
    Nov 2017
    iasi
    Quote Originally Posted by Styber View Post
    D8CA4 - set to 0
    I don't know how to set the adress to 0
    It's enough this change to have a proper DPF off?
    foxFlash's Avatar
    Aug 2024
    Quote Originally Posted by darckreign1984 View Post
    Engine: 2.0 HDi
    HW: 9663548180
    SW: 9667098880
    Thank you!
    Here is your file mate !! Reset DPF then write !!
    THX+REP !! PM for pass !!!
    ​HIT THX+REP BUTTON IF I HELP YOU !!!
