Results 1 to 9 of 9
    kevfield's Avatar
    uk
    Default Renault Clio coil driver
    i have renault clio with coil driver down, found in ecu Regulator burnt out part number N436AH 14CL40 does anyone have data sheet for this or can tell me if BST2140-b1 will be ok as i have in stock.
    Thanks kev
    DK Veteran avtonega's Avatar
    EU
    Can you explain, wich ECU is it?!
    Top Poster + cristi_onofrei's Avatar
    Iasi, Romania
    BTS 2140 must be OK, or other IGBT with min 14A, 600V
    like 5401DM, 20CL36, etc
    Portugal
    You can put BTS2140 without any problem.
    Best Regards,
    Nuno
    sometimes simple solution is get one from a breakers yard and rob the bits
    just had a unit repaired by one of the ecu repair companies,opened it to find they have used a bts2140
    Jun 2011
    near bigest capacitor
    Quote Originally Posted by baltazar3 View Post
    Look and check supply for driver...if not change with another one.
    i have same problem at renault scenic sirius 32 ecu.i changed bts2140 s but problem is still going why?
    baltazar3's Avatar
    Andromeda
    '" live and learn........ if you wont ....you ain't "
    _______ . ____ . __ . __ . _______ . __ __ __ ... ---
    If my post was HELPFUL please push THANKS button
    Jun 2011
    which ic is supply?
