    Aug 2015
    Default DPF OFF Mini Cooper 1,6L hdi
    I need help to delete DPF.
    Vehicle Mini Cooper 1,6L hdi PSA
    Ecu Bosch EDC16C35
    Additive pump is HS
    i search a good solution to delete DPF and Additive Pump.
    Thank you,
    Mat
    Nov 2017
    Maroc
    Default DPF OFF
    THANKS + REP
    PASS PM
  3. The Following User Says Thank You to yassine hadd For This Useful Post:
    matt1781 (29th August, 2024)
    Aug 2015
    Hi Yassine,
    Thank you for your job but your solution don't work.
    i searched a good solution with additive pump off.
    Thank you,
    Aug 2015
    Hi i searched a good solution with additive pump OFF.
    I can pay for it.
    Thank you,
    Mat
    Aug 2015
    I can pay for it.
    Thank you,
    Mat
    Nov 2017
    Maroc
    Quote Originally Posted by matt1781 View Post
    Ecu Bosch EDC16C35
    Additive pump is HS
    Thank you,
    Mat
    sende code errour
