Results 1 to 8 of 8
    Jun 2016
    Default TC222-16F VVDI pinout
    Hello, does anyone have pinout for vvdi prog
    Mexaniks's Avatar
    Mar 2013
    UA ODESSA
    Hello. Don’t be shy, open it - everything is obvious there
    fuzz1's Avatar
    Jul 2019
    Quote Originally Posted by Mexaniks View Post
    A full strip is required and obviously you have to show us the pics
    Mexaniks's Avatar
    Mar 2013
    UA ODESSA
    In these ECUs, the board is made so that you can see with your eyes where you need to connect. You just need to open the connection diagram and connect.
    The author of the post simply didn’t even look at the board. The pads are next to the MCU and located opposite each desired pin.
    So simple that you only need a soldering iron and instructions for connecting the plugs in the programmer
  5. The Following User Says Thank You to Mexaniks For This Useful Post:
    danielif (30th August, 2024)
    Apr 2014
    Spain
    Here pinout, dont forget Thanks/reputation butons...
    Regards.
    Don't forget to press the THANKS & REPUTATION button for help in the future.
  7. The Following 4 Users Say Thank You to danielif For This Useful Post:
    julo45 (30th August, 2024), Mexaniks (6th September, 2024), precel1974 (24th September, 2024), pvkosherov (2nd September, 2024)
  8. #6
    Jun 2016
    Thank for everyone's replies but customer didn't want to open the module, so I give it him back
  9. #7
    Mexaniks's Avatar
    Mar 2013
    UA ODESSA
    Quote Originally Posted by pvkosherov View Post
    Should the client turn to the sorcerers?
  10. #8
    Jun 2016
    Maybe there is someone who have more tools and can make.it by obd
