Denso 55577647
MB275800-884
Attached full bench read by flex.
Can someone calculate Pin code?
Denso 55577647
MB275800-884
Working on something to release next month for free for all dk users :>
Security Code is 9973
Do not forget to press Thanks and Reputation buttons!
autodigitec (10th September, 2024)
9973 or swap
IF I HELPED YOU, PLEASE REMEMBER TO PRESS THANKS AND REPUTATION.
pin code 9973 adr 790 in hex 39 c6 39 c6 37 c8 33
Thanks everyone, your code is the same as request on dealer by VIN. However I'm not being able to renew or even insert code in bench. I will see if I can test on car.
"Also, do you know if changing those bytes is enough to accept a different code?"
What is the point of these actions? If you reset this ECU, you can write any code there.
If the PIN code changes, both the key crypt and the ECU synchronization crypt will change.
If you change the pin manually, I cannot imagine what consequences this will lead to.
