Results 1 to 7 of 7
    autodigitec's Avatar
    Aug 2011
    PT
    Default Opel Astra J 2011 Denso ECU, read pin code
    Denso 55577647
    MB275800-884
    Attached full bench read by flex.
    Can someone calculate Pin code?
    Regards
    Working on something to release next month for free for all dk users :>
    Aug 2018
    Romania
    Security Code is 9973
    Do not forget to press Thanks and Reputation buttons!
  3. The Following User Says Thank You to sebage For This Useful Post:
    autodigitec (10th September, 2024)
    s qubiak's Avatar
    Jun 2017
    Polska
    9973 or swap
    IF I HELPED YOU, PLEASE REMEMBER TO PRESS THANKS AND REPUTATION.
  5. The Following User Says Thank You to s qubiak For This Useful Post:
  6. #4
    Sep 2009
    Belarus
    pin code 9973 adr 790 in hex 39 c6 39 c6 37 c8 33
  7. The Following User Says Thank You to Jur For This Useful Post:
  8. #5
    Aug 2011
    PT
    Thanks everyone, your code is the same as request on dealer by VIN. However I'm not being able to renew or even insert code in bench. I will see if I can test on car.
  9. #6
    Aug 2011
    PT
    Quote Originally Posted by Jur View Post
    Also, do you know if changing those bytes is enough to accept a different code?
  10. #7
    Sep 2009
    Belarus
    "Also, do you know if changing those bytes is enough to accept a different code?"
    What is the point of these actions? If you reset this ECU, you can write any code there.
    If the PIN code changes, both the key crypt and the ECU synchronization crypt will change.
    If you change the pin manually, I cannot imagine what consequences this will lead to.
