Results 1 to 3 of 3
    Apr 2017
    Default Marelli 9DF delete recovery from map
    I have a problem with a fiat 1.6 MJ engine mounted on an Opel. The machine continually goes into recovery due to problems relating to the turbine control. Mechanically everything is fine but I can't solve it. On other vehicles I managed to eliminate the recovery by acting on the relevant maps. Is it possible to do it also on this ECU?
    Dec 2022
    it is due to bad ecu
    carmageddon's Avatar
    Italy
    they dont exist engine 1.6 with 9DF....your file are from combo/doblo 1.3 mjet 95 hp 4F42D324_55281051...write here dtc list
