Results 1 to 15 of 28
    DK Veteran sl4ck's Avatar
    Default E39 520D 136HP Bosch 0281010205 bad flash
    M8's need help please, i went to a bad flash with BMW E39 520D 136HP.
    First i was able to recover original file with galletto, and i flashed with another one not compatible, i didn?t know, now i'm trying to flash with original one but it gives INIT ERROR.
    With a more extensive search i was able to find out that it uses two files?! HI and LO ?!
    Has far has i know ECU files from 136HP e46(320d) and e39(520d) are the same, i have them both(HI and LO), but how can i flash it?
    Should i use my original i read from my ECU, but it's not HI neither LO or use this ones, and how can i flash them both?!
    bmw320d's Avatar
    You can write it directly with a programmer plcc32, or modify the two dump into one, in this case you can upload in the ecu with galletto
    When we use galletto to read original dump from this ECU it reads the two files buy into one?
    What's the difference between HI and LO ?
    How can i modify the two files into one ?
    How can i upload it with galletto if it has INIT -1 ERROR ??
    Sorry but i?m really mad, because it's my daily car.
    VOLUMAX's Avatar
    Rousse Bulgaria
    Now I think that there have only one method for recovery . Desolder the two plcc32 chips and write them on the programmer !
    Are there two chips?
    How do i know wich one is HI and LO ?
    Can i split my galletto file into one, or galletto only reads one chip?
    VOLUMAX's Avatar
    Rousse Bulgaria
    Yes there are two chips inside the ECU !
    Galleto join the two files in one while reading them !
    2 X 128 kB = 1 X 256 kB
    can you help me identifying the chips ?
    HI and LO
    VOLUMAX's Avatar
    Rousse Bulgaria
    Here is it
    What's chip's identification to use in programmer?
    Both have stickers with numbers on top like:
    351343010205110161
    and
    351344010205110161
    and i don?t whant to remove them.
    Thanks again
    VOLUMAX's Avatar
    Rousse Bulgaria
    There are Flash PLCC 32 29F010
    The first 6 digits are a SW ! X XXX 351 343 is Lo bite chip and X XXX 351 344 is Hi bite !
    The second 6 digits are HW of ECU X XXX 010 205
    Maybe you don't want but have
    After i flash both HI and LO chip's with PLCC32 adapter and a programmer with files posted on first post (downloaded from another forum) car didn?t start again, but galletto INIT error stopped and i was able to flash it again with galletto my original flash i had saved with galletto.
    Can someone explain why car didn?t start with files posted on first post?
    bmw320d's Avatar
    Quote Originally Posted by sl4ck View Post
    You use socket plcc32? or the eprom are directly on pcb? after having upload the file in the eprom with the programmer you has verified if the dump are the same? the file upload in eprom has the correct checksum?
  13. #13
    I have desoldered the two chips and programmed with the PLCC32 to DIP adapter.
    Dunno if the checksum was the same, but after i flashed the two desoldered chips with the programmer i was able to program ECU with galletto and with my galletto saved file (256kb) i had done before
    Maybe it doesn?t start with the two first files because immo? Where is Immo in this ECU?
    Is there any way to split my original galletto saved file in two (HI and LO) ?
  14. #14
    bmw320d's Avatar
    Maybe it doesn?t start with the two first files because im*o? Where is im*o in this ECU?
    the immo is in the two eprom and in the e2prom 24c02, upload here your full dump 256kb from galletto, so I can split it in Hi e Lo
  15. #15
    I'll do when i be at home.
    So, the car could not start because of the immo in the files in first post aren?t from my car and immo info is not the same, could be because of this?
