Results 1 to 15 of 29
    Aug 2016
    Default Best way for read 95128/256 in FEM w/o remove eeprom
    Which programmer read success eeprom from FEM without remove from fem? I try with im508 xp400 but not success.
    Mar 2018
    UK
    Autel read it without problem but you must clean lacquer from the eeprom
    Also if you do it with Autel careful look when you must disconnect the clip
  3. The Following User Says Thank You to Manta1600 For This Useful Post:
    MaxMin (26th September, 2024)
    fuzz1's Avatar
    Jul 2019
    Hi. What's the problem that occurs when you remove the clip?
  5. The Following User Says Thank You to fuzz1 For This Useful Post:
  6. #4
    Aug 2016
    I try milion time with autel but not possible,eeprom is clear but not success
    Mar 2018
    UK
    Quote Originally Posted by fuzz1 View Post
    When you read/write the eeprom the power on the FEM must be Off
    When you downgrade the FEM the clip must be disconnected
    If not follow this is possible to have nice clicking sound
  8. The Following 8 Users Say Thank You to Manta1600 For This Useful Post:
    emanuel2010 (26th September, 2024), fuzz1 (25th September, 2024), MaxMin (26th September, 2024), musti418 (26th September, 2024), p1et (25th September, 2024), richard27 (2nd October, 2024), rokibar (26th September, 2024), wuza (28th September, 2024)
  9. #6
    Mar 2018
    UK
    Quote Originally Posted by MaxMin View Post
    Replace the clip
  10. #7
    p1et's Avatar
    Oct 2013
    Try with acdp clip
  11. The Following User Says Thank You to p1et For This Useful Post:
  12. #8
    fuzz1's Avatar
    Jul 2019
    Given that the chip is glued but the legs aren't just use an air gun and a scalpel. Slide the scalpel under the legs and separate them from the board. Then just solder on the legs
  13. #9
    rob h's Avatar
    May 2011
    To clean, use paint stripper, sold in spray can.
    Leave it on, about 10minutes, and clean it with brakecleaner.
    Dont removed it.
    Reading in circuit, lower voltage to 3.3volt.
    Use a programmer, that monitors leg connections. ( Orange5 is my favorit )
    I use this clamp, autel, and xhorse sell these:
    YANHUA FEM/BDC Special Programming Clip Can Work With Yanhua ACDP, CGDI, VVDI, Autel
    Dont connected, fem, to your keytool, during the prog connection. And vice versa.
  14. The Following 3 Users Say Thank You to rob h For This Useful Post:
    MaxMin (26th September, 2024), musti418 (26th September, 2024), wuza (28th September, 2024)
  15. #10
    Retired Sat TV Addict
    .: JaCkPoT :.'s Avatar
    Aug 2008
    var/tuxbox/plugins
    Is the clip the right way? Im guessing you know, but you need to pay attention to the red coloured wire and its position on the chip
    Read the Rules here; they apply to Everyone.
    ___________________
    In the good old days, I had
    DM800s HD
    Openbox S10
    TM500
    DM500s
    90cm FortecStar dish
    Technomate 2300 Motor
  16. The Following User Says Thank You to .: JaCkPoT :. For This Useful Post:
  17. #11
    rob h's Avatar
    May 2011
    Even if you connect it the wrong way around, it is fine.
    It wont damage it.
    But if you worry, Just look for a prog, that tells you, if it is connected fine, on all legs.
    Upa, does not show it well, not like orange5.
    vvdiprog, shows nothing. So dont choose that.
    orange5 clone first version, like mine is perfect.
    About the latest clones, i dont know.
    I have a new 1.42, but not tested it
  18. The Following User Says Thank You to rob h For This Useful Post:
  19. #12
    TeL200's Avatar
    Worcester UK
    Orange-5 incircuit for me
    Auto Locksmith / Security Professional
  20. The Following User Says Thank You to TeL200 For This Useful Post:
  21. #13
    Feb 2017
    Tunisia
    i use acdp clip never failed
    Welcome all , I'm here to give help if i could to evrey one , I'm not here to collect thanks and recompense because i know that a locksmith is quite risky job and i experienced my self what this means for that it's a duty to offer my help to all dk members..
  22. The Following User Says Thank You to issam216 For This Useful Post:
  23. #14
    Aug 2016
    I use acdp adapter but not possible to read.
  24. #15
    Aug 2016
    I found the problem,pinch from this acdp adapter is not OK, i solder wire like in picture and read success
  25. The Following User Says Thank You to MaxMin For This Useful Post:
    adhdbaby (27th September, 2024)
