Which programmer read success eeprom from FEM without remove from fem? I try with im508 xp400 but not success.
Autel read it without problem but you must clean lacquer from the eeprom
Also if you do it with Autel careful look when you must disconnect the clip
MaxMin (26th September, 2024)
Hi. What's the problem that occurs when you remove the clip?
I try milion time with autel but not possible,eeprom is clear but not success
Given that the chip is glued but the legs aren't just use an air gun and a scalpel. Slide the scalpel under the legs and separate them from the board. Then just solder on the legs
To clean, use paint stripper, sold in spray can.
Leave it on, about 10minutes, and clean it with brakecleaner.
Dont removed it.
Reading in circuit, lower voltage to 3.3volt.
Use a programmer, that monitors leg connections. ( Orange5 is my favorit )
I use this clamp, autel, and xhorse sell these:
YANHUA FEM/BDC Special Programming Clip Can Work With Yanhua ACDP, CGDI, VVDI, Autel
Dont connected, fem, to your keytool, during the prog connection. And vice versa.
___________________
In the good old days, I hadDM800s HDOpenbox S10
TM500
DM500s
90cm FortecStar dish
Technomate 2300 Motor
Even if you connect it the wrong way around, it is fine.
It wont damage it.
But if you worry, Just look for a prog, that tells you, if it is connected fine, on all legs.
Upa, does not show it well, not like orange5.
vvdiprog, shows nothing. So dont choose that.
orange5 clone first version, like mine is perfect.
About the latest clones, i dont know.
I have a new 1.42, but not tested it
Orange-5 incircuit for me
Auto Locksmith / Security Professional
i use acdp clip never failed
Welcome all , I'm here to give help if i could to evrey one , I'm not here to collect thanks and recompense because i know that a locksmith is quite risky job and i experienced my self what this means for that it's a duty to offer my help to all dk members..
I use acdp adapter but not possible to read.
I found the problem,pinch from this acdp adapter is not OK, i solder wire like in picture and read success
adhdbaby (27th September, 2024)
